주요 콘텐츠로 건너뛰기
Acer Chromebook R11 C738T-C44Z Motherboard Replacement
필요한 것
  1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: 2 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: 2 단계, 이미지 2/2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 4 단계, 이미지 1/1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: 5 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: 5 단계, 이미지 2/2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  6. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  7. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 7 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 7 단계, 이미지 2/2
    • Carefully slide the wireless card out of its socket from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 8 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 8 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 8 단계, 이미지 3/3
    • Disconnect the LED board ribbon by pulling it out gently.
    • Disconnect the speaker cable.
  9. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 9 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 9 단계, 이미지 2/2
    • Disconnect the keyboard ribbon.
    • Slide it out gently to not rip it.
  10. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 10 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 10 단계, 이미지 2/2
    • Disconnect the daughterboard ribbon by flipping up the white tab and pulling it out from the motherboard.
  11. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 11 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 11 단계, 이미지 2/2
    • Disconnect the touchpad ribbon by lifting up the tab and pulling it out.
  12. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 12 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 12 단계, 이미지 2/2
    • Disconnect the sensor cable by pulling it out.
  13. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 13 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 13 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 13 단계, 이미지 3/3
    • Disconnect the LCD cable by pinching it and lifting it off the motherboard.
  14. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 14 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 14 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws that hold the hinge down.
  15. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 15 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 15 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 15 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the motherboard.
  16. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 16 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 16 단계, 이미지 2/2
    • Slide the opening tool underneath the hinge latch to lift it up.
    • This is to free the motherboard.
  17. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 17 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 17 단계, 이미지 2/2
    • Grab the motherboard securely to lift and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connie Hernandez
회원 가입일: 09/01/21
517 평판
안내서 4개 작성하였습니다
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 34
전체 시간: 480
