주요 콘텐츠로 건너뛰기
Acer Chromebook R11 C738T-C44Z Speakers Replacement
필요한 것
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 1 단계, 이미지 3/3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: 2 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: 2 단계, 이미지 2/2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 3 단계, 이미지 1/1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 4 단계, 이미지 1/1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: 5 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: 5 단계, 이미지 2/2
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 6 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 6 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 6 단계, 이미지 3/3
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 7 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 7 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 7 단계, 이미지 3/3
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 8 단계, 이미지 1/1
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 9 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 9 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 9 단계, 이미지 3/3
    • Gently lift the speakers up and remove the cable from the system.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connie Hernandez
회원 가입일: 09/01/21
517 평판
안내서 4개 작성하였습니다
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 12
전체 시간: 108
