주요 콘텐츠로 건너뛰기
Acer Chromebook R11 C738T-C44Z Touchpad Replacement
필요한 것
  1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: 1 단계, 이미지 3/3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: 2 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: 2 단계, 이미지 2/2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: 3 단계, 이미지 1/1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: 4 단계, 이미지 1/1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: 5 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: 5 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: 5 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the touchpad.
    • Lift up the tab for the cable cord.
    • Pull out the touchpad connector.
  6. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: 6 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: 6 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: 6 단계, 이미지 3/3
    • Pull the left piece of tape up by prying it up with your fingers or with the screwdriver.
    • Be gentle to not rip the tape.
    • Next, pull up the other piece of tape.
    • Remove the touchpad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connie Hernandez
회원 가입일: 09/01/21
517 평판
안내서 4개 작성하였습니다
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you, Connie Fernandez. ~Super
Super - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 16
전체 시간: 311
