주요 콘텐츠로 건너뛰기
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
필요한 것
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: 1 단계, 이미지 3/3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: 2 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: 2 단계, 이미지 2/2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: 4 단계, 이미지 1/2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: 4 단계, 이미지 2/2
    • Carefully slide the wireless card out of its socket from the motherboard.
결론
Connie Hernandez
회원 가입일: 09/01/21
517 평판
안내서 4개 작성하였습니다
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 314
