주요 콘텐츠로 건너뛰기
Acer Chromebook R11 CB5-132T-C1LK Battery Replacement
필요한 것
  1. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out by pulling upward.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alan Shan
회원 가입일: 04/26/17
382 평판
안내서 3개를 작성함
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G2
4 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 33
전체 시간: 4,769
