주요 콘텐츠로 건너뛰기
Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement
필요한 것
  1. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: 2 단계, 이미지 1개 중 1개
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: 3 단계, 이미지 2개 중 1개 Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
    • Pull the ribbon cable from the ZIF connector using tweezers.
  4. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: 4 단계, 이미지 1개 중 1개
    • Remove the 4.5 mm Phillips screw.
    • There is a magnet near the LED chip that might attract the screw.
  5. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: 5 단계, 이미지 1개 중 1개
    • Use tweezers to remove the LED board.
결론
작성자
4다른 기여자 명과 함께
Alan Shan
회원 가입일: 04/26/17
382 평판
안내서 3개를 작성함
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,082
