주요 콘텐츠로 건너뛰기
Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement
필요한 것
  1. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out by pulling upward.
  6. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 1개 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift the retaining flaps of the two ZIF connectors into the upright position using the flat end of the spudger.
    • Unplug the tabs from the connectors by gently pulling them out with the tweezers.
  7. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Slide back both sides of the locking mechanism of the touchpad using the narrow end of the spudger.
    • Unplug the trackpad wire by gently pulling it out of the connector with the tweezers.
  8. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 8 단계, 이미지 1개 중 1개
    • Unplug the audio connector from the motherboard with the tweezers.
    • Be sure to pull the plug by holding it at the base, not yanking on the wires, as this could damage the device.
  9. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 9 단계, 이미지 1개 중 1개
    • Pop the speakers off of the device by hand.
    • They are held on only by a mild adhesive and should come off easily.
결론
작성자
6다른 기여자 명과 함께
Harrison DeWitt
회원 가입일: 04/26/17
101 평판
안내서 1개를 작성함
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G2
4 회원들
안내서 12개를 작성함
1가이드 댓글
Hi, do you know how to replace the microphone on this chromebook?
Álvaro Guzmán Parrochia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 746
