주요 콘텐츠로 건너뛰기
Acer Chromebook R11 Speakers Replacement
필요한 것
  1. Acer Chromebook R11 Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery by pulling upwards.
  5. Acer Chromebook R11 Speakers Replacement, Speakers: 5 단계, 이미지 2개 중 1개 Acer Chromebook R11 Speakers Replacement, Speakers: 5 단계, 이미지 2개 중 2개
    • Slide out black ribbons connecting speakers to motherboard
    • Connected on lower left-hand side of motherboard
    • When removing wires, remove gently with respect to metal clips along wires that are holding them in place.
    • Slide out white ribbon connecting keyboard to motherboard
  6. Acer Chromebook R11 Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull speakers upwards
    • Adhesive is below it
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Victoria May
회원 가입일: 02/16/17
119 평판
안내서 1개를 작성함
USF Tampa, Team 1-2, Kass Spring 2017 USF Tampa, Team 1-2, Kass Spring 2017 회원
USFT-KASS-S17S1G2
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 20
전체 시간: 538
