소개
Here the replacement guide for the touchpad. If you notice that clicks are not registering or the mouse won't move even though you are dragging your finger across the pad, then it may need to be replaced.
필요한 것
Unscrew the 12 back screws, circled in red. The top 8 screws are 4.90mm x 5.71mm.
The 4 screws on the bottom are 4.81mm x 4.6mm.
Pry the casing off by running a thin tool, like an opening pick, between the over and the sides
거의 끝나갑니다!
결론
