주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement
필요한 것
  1. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: 1 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: 1 단계, 이미지 2개 중 2개
    • Separate screen casing using a nylon spudger and a metal spudger.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Peel the tape back.
    • Lift the red bar laying across the connection with the spudger.
    • Pull the connection out.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the two cords shown by gently pulling them apart near their connection point.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the connection by gently pulling on it.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Unravel the cord from around the screen and lift up on the screen to remove.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, Display Assembly: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove all twelve 6 mm screws in the bottom panel of the Chromebook.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Use an opening tool to pry open the Chromebook casing starting from the corners.
  8. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the 6 mm hinge screws on the right side of the Chromebook.
  9. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the end of LCD cable that is connected to the motherboard. Lift the connector's ZIF tab and gently pull the ribbon cable free.
    • Disconnect the other end of the LCD cord from the left side of the motherboard.
  10. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • The LCD cable has been disconnected and can be removed by guiding it out of the hooks that keeps it in placed.
결론
작성자
1다른 기여자 명과 함께
Bailey Johnson
회원 가입일: 03/21/22
718 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 732
