주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement
필요한 것
  1. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the Chromebook face down.
    • Use a Phillips #0 screwdriver to remove the twelve 6 mm screws that secure the bottom cover.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an opening tool in the seam between the outer covers. Pushing down on the edge of the opening tool will cause the cover to lift up and reveal the internal components.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the connecting cord between the battery and the motherboard and pull towards you to disconnect.
    • Remove any tape holding the battery cord down by pulling up on it.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • The battery is no longer connected to the Chromebook allowing you to lift up and remove the battery.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement, Speakers: 5 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement, Speakers: 5 단계, 이미지 2개 중 2개
    • The speakers are connected a small amount of adhesive tape. They can be pulled out by gripping them and gently wiggling them up and out.
    • Unplug the cord connecting the speaker to the motherboard by gripping it on the sides and pulling.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the 3 mm screw that secures the trackpad. Lift the trackpad away to expose the cord connecting the two speakers.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the cord out from the hooks to remove it.
결론
작성자
1다른 기여자 명과 함께
Bailey Johnson
회원 가입일: 03/21/22
691 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 328
