주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement
필요한 것
  1. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the Chromebook face down.
    • Use a Phillips #0 screwdriver to remove the twelve 6 mm screws that secure the bottom cover.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an opening tool in the seam between the outer covers. Pushing down on the edge of the opening tool will cause the cover to lift up and reveal the internal components.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the connecting cord between the battery and the motherboard and pull towards you to disconnect.
    • Remove any tape holding the battery cord down by pulling up on it.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: 4 단계, 이미지 1개 중 1개
    • The battery is no longer connected to the Chromebook allowing you to lift up and remove the battery.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement, Track Pad: 5 단계, 이미지 1개 중 1개
    • Pull the tape back and unplug the cable connecting the track pad to the motherboard by gently pulling back on it.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the track pad in place.
    • 3 of the screws are located below the black film that must be lifted up to expose them.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up on the track pad to remove it out of the Chromebook.
결론
작성자
1다른 기여자 명과 함께
Bailey Johnson
회원 가입일: 03/21/22
691 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 412
