주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement
필요한 것
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Back Cover: 1 단계, 이미지 2/2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 2 단계, 이미지 1/3 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 2 단계, 이미지 2/3 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 2 단계, 이미지 3/3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Display Screen: 3 단계, 이미지 1/2 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Display Screen: 3 단계, 이미지 2/2
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 4 단계, 이미지 1/3 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 4 단계, 이미지 2/3 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 4 단계, 이미지 3/3
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 5 단계, 이미지 1/3 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 5 단계, 이미지 2/3 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Evan Costa
회원 가입일: 10/29/19
503 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 UMass Dartmouth, Team S4-G1, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G1
3 회원들
안내서 5개 작성하였습니다
댓글 2개
I just want to say that I’ve used this guide several times. My kid dropped the laptop and broke the hinge which is located inside the top cover behind the LCD panel. When this happened, it caused the grommets to come out of the plastic. But for about $45 we replaced the hinge and the top cover and I was able to fix it and put it all back together. I appreciate having this guide to remind me. Thank you!
Christopher Rayment - 답글
Thank you so much for these instructions! The connections were the hardest part for me and the pictures were a great help.
Wendy Brooks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 2,175
