소개
If your Acer Chromebook Spin 511 (C741L) N20Q8 is not turning on or losing its charge rapidly, the battery may be faulty and need a replacement.
By replacing the Chromebook's battery, it will be able to stay powered on for longer. It will no longer need to be charged as often.
Power down the device before performing the steps in the guide.
필요한 것
Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
Gently remove the electrical tape from the battery.
Detach the colored wires from the wire connector on the motherboard.
Remove the battery from the laptop.
다른 2명이 해당 안내서를 완성하였습니다.
