주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement
필요한 것
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Gently remove the electrical tape from the battery.
    • Detach the colored wires from the wire connector on the motherboard.
    • Remove the battery from the laptop.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
    • Flip the gray hinges up.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two metal plates that were previously held down by each hinge.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Detach the connector from the motherboard.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Gently remove the blue, yellow, and black wires from their connectors.
  8. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the tape from the black connector and gently remove it from the socket.
  9. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully remove the pin connector containing the black, white, and red wires from its socket.
  10. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Detach the long connector from the socket.
    • Remove the motherboard from the device.
결론
작성자
3다른 기여자 명과 함께
Lauryn F
회원 가입일: 09/26/24
722 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 27
전체 시간: 336
