주요 콘텐츠로 건너뛰기
Acer Chromebook cb3-532-c47c Display Assembly Replacement
필요한 것
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: 3 단계, 이미지 1개 중 1개
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: 4 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: 4 단계, 이미지 2개 중 2개
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: 5 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: 5 단계, 이미지 2개 중 2개
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: 6 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: 6 단계, 이미지 2개 중 2개
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 7 단계, 이미지 3개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 7 단계, 이미지 3개 중 2개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 7 단계, 이미지 3개 중 3개
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: 8 단계, 이미지 1개 중 1개
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: 10 단계, 이미지 1개 중 1개
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 11 단계, 이미지 2개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 11 단계, 이미지 2개 중 2개
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 12 단계, 이미지 3개 중 1개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 12 단계, 이미지 3개 중 2개 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 12 단계, 이미지 3개 중 3개
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jerry Wheeler
회원 가입일: 03/21/22
72,217 평판
안내서 71개를 작성함
Oregonians Oregonians 회원
Community
8 회원들
안내서 189개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 3
전체 시간: 350
