소개
The central processing unit (CPU) is the brain of your computer. It is responsible for executing program instructions and performing basic arithmetic and logical operations. If your Acer E5-571-54FL is experiencing glitches or displaying a blue screen, the CPU may need repairs. Follow the instructions in this guide to replace the CPU in your Acer E5-571-54FL laptop. Before beginning, power off the device and unplug it from the charger.
필요한 것
Locate the CPU cooling fan in the upper left corner of the laptop.
Using a #0 Phillips screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
Locate the WiFi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
Carefully lift the white coaxial cable up and forward to disconnect the it from the WiFi card.
Repeat the previous two bullet points to disconnect the black coaxial cable from the WiFi card.
Locate the hard drive and its carriage at the lower right corner of the laptop.
Release the USB port ribbon cable by using the plastic opening tool to carefully lift up the black locking tab of the ZIF connector.
Move the USB port ribbon cable to the side.
Locate the two 3 mm Phillips screws holding the hard drive into the carriage. There is one screw on each side of the carriage.
Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
Using a #0 Phillips screwdriver, remove the 3 mm screw to release the side of the hard drive from the carriage.
Repeat the two previous bullet marks to remove the second 3 mm Phillips screw. This should also free the hard drive from the carriage.
Carefully lift up on the right edge of the motherboard near the hard drive connector.
With minimal force, pull the motherboard to the right freeing the ports on the left from the case.
Put down the right side and allow the motherboard to rest in the case.
Lift the left side of the motherboard up and turn it over so the ports are now facing right.
Congratulations! You have successfully completed the process of replacing the CPU in your Acer E5-571-54FL laptop. This guide provides step-by-step instructions, guiding you through the disassembly of various components such as the battery, keyboard, cooling fan, WiFi card, hard drive, and motherboard. Carefully following each step ensures a smooth disassembly process.
Remember to exercise caution and use the appropriate tools to avoid damage during the procedure. If you encounter any resistance or difficulties, double-check the connections and components to ensure everything is properly disconnected. Take your time, and do not hesitate to refer back to specific steps if needed.
To reassemble your device, simply follow the instructions in reverse order. Start by reconnecting the motherboard, securing it with screws, and reconnecting any detached components. Be sure to tighten all screws securely but avoid over-tightening. Finally, reattach the battery and power on your Acer E5-571-54FL.
If you find this guide helpful, consider providing feedback or sharing your experience. If you encounter any challenges or have suggestions for improvement, feel free to contribute to the community. Thank you for using this guide, and best of luck with your newly replaced CPU!
