주요 콘텐츠로 건너뛰기
Acer E5-571-54FL TrackPad Replacement
필요한 것
  1. Acer E5-571-54FL TrackPad Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL TrackPad Replacement: 2 단계, 이미지 1/2 Acer E5-571-54FL TrackPad Replacement: 2 단계, 이미지 2/2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL TrackPad Replacement: 3 단계, 이미지 1/2 Acer E5-571-54FL TrackPad Replacement: 3 단계, 이미지 2/2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL TrackPad Replacement, Keyboard: 4 단계, 이미지 1/1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL TrackPad Replacement: 5 단계, 이미지 1/1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL TrackPad Replacement: 6 단계, 이미지 1/1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL TrackPad Replacement: 7 단계, 이미지 1/1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL TrackPad Replacement: 8 단계, 이미지 1/3 Acer E5-571-54FL TrackPad Replacement: 8 단계, 이미지 2/3 Acer E5-571-54FL TrackPad Replacement: 8 단계, 이미지 3/3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL TrackPad Replacement: 9 단계, 이미지 1/1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL TrackPad Replacement: 10 단계, 이미지 1/3 Acer E5-571-54FL TrackPad Replacement: 10 단계, 이미지 2/3 Acer E5-571-54FL TrackPad Replacement: 10 단계, 이미지 3/3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL TrackPad Replacement: 11 단계, 이미지 1/3 Acer E5-571-54FL TrackPad Replacement: 11 단계, 이미지 2/3 Acer E5-571-54FL TrackPad Replacement: 11 단계, 이미지 3/3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL TrackPad Replacement: 12 단계, 이미지 1/3 Acer E5-571-54FL TrackPad Replacement: 12 단계, 이미지 2/3 Acer E5-571-54FL TrackPad Replacement: 12 단계, 이미지 3/3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL TrackPad Replacement: 13 단계, 이미지 1/3 Acer E5-571-54FL TrackPad Replacement: 13 단계, 이미지 2/3 Acer E5-571-54FL TrackPad Replacement: 13 단계, 이미지 3/3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL TrackPad Replacement, TrackPad: 14 단계, 이미지 1/1
    • Remove the screw at the bottom of the track pad using the Phillips #0 screwdriver.
  15. Acer E5-571-54FL TrackPad Replacement: 15 단계, 이미지 1/2 Acer E5-571-54FL TrackPad Replacement: 15 단계, 이미지 2/2
    • Gently remove the copper adhesive strips attached to the track pad.
    • Remove the two screws using the Phillips #0 screwdriver.
  16. Acer E5-571-54FL TrackPad Replacement: 16 단계, 이미지 1/2 Acer E5-571-54FL TrackPad Replacement: 16 단계, 이미지 2/2
    • Pop the track pad out of of the keyboard casing and remove it from the device.
결론
Jennifer Hancock
회원 가입일: 09/19/19
325 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 418
