주요 콘텐츠로 건너뛰기
Acer Ferarri 4000 Hard Drive Replacement
필요한 것
  1. Acer Ferarri 4000 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Acer Ferarri 4000 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • The Ferrari 4000 ships with a PATA hard drive, which you will have the full knowledge to replace time and time again once you're done.
    • It's so easy, even a caveman can do it.
    • I cannot endorse the previous point since all cavemen are extinct.
  2. Acer Ferarri 4000 Hard Drive Replacement, Opening Up the Laptop: 2 단계, 이미지 3개 중 1개 Acer Ferarri 4000 Hard Drive Replacement, Opening Up the Laptop: 2 단계, 이미지 3개 중 2개 Acer Ferarri 4000 Hard Drive Replacement, Opening Up the Laptop: 2 단계, 이미지 3개 중 3개
    • Let's get started by removing these two Phillips #0 screws holding down the hard drive bay cover on the bottom of the computer near the 3 USB ports.
    • These screws do not come completely out - they are meant to stay attached to the cover so you don't lose them.
    • Lift the bay cover to expose the drive cover
  3. Acer Ferarri 4000 Hard Drive Replacement, Protective Grille: 3 단계, 이미지 3개 중 1개 Acer Ferarri 4000 Hard Drive Replacement, Protective Grille: 3 단계, 이미지 3개 중 2개 Acer Ferarri 4000 Hard Drive Replacement, Protective Grille: 3 단계, 이미지 3개 중 3개
    • The only thing separating you from the hard drive glory is a drive cover that looks oddly like a sports car grille...
    • Remove the 4 Phillips #0 screws.
    • Do not lift the cover just yet: there are two more screws securing it to the computer. If you lift it now, you risk bending the metal and damaging the cover.
    • Pull the tab to free the grille from the drive.
  4. Acer Ferarri 4000 Hard Drive Replacement, Removal: 4 단계, 이미지 3개 중 1개 Acer Ferarri 4000 Hard Drive Replacement, Removal: 4 단계, 이미지 3개 중 2개 Acer Ferarri 4000 Hard Drive Replacement, Removal: 4 단계, 이미지 3개 중 3개
    • Pull back with a spudger (or your fingernails) where the drive plugs in to the computer.
    • Put your fingers where the red circles are and swing the drive up. Once it's up an adequate amount, grab it by its sides and pull it out of the computer.
  5. Acer Ferarri 4000 Hard Drive Replacement, You're finished!: 5 단계, 이미지 1개 중 1개
    • You're done with the removal! Follow these instructions in reverse to install the new drive.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Nathanael
회원 가입일: 02/03/14
974 평판
안내서 2개를 작성함
Beautiful Savior Lutheran Church Beautiful Savior Lutheran Church 회원
Business
1 회원
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 27
전체 시간: 3,062
