주요 콘텐츠로 건너뛰기
Acer Iconia A1-810 Motherboard Replacement
필요한 것
  1. Acer Iconia A1-810 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
  2. Acer Iconia A1-810 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Motherboard Replacement: 3 단계, 이미지 1/1
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
  4. Acer Iconia A1-810 Motherboard Replacement: 4 단계, 이미지 1/2 Acer Iconia A1-810 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove battery from adhesive.
  5. Acer Iconia A1-810 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
  6. Acer Iconia A1-810 Motherboard Replacement: 6 단계, 이미지 1/2 Acer Iconia A1-810 Motherboard Replacement: 6 단계, 이미지 2/2
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
  7. Acer Iconia A1-810 Motherboard Replacement: 7 단계, 이미지 1/3 Acer Iconia A1-810 Motherboard Replacement: 7 단계, 이미지 2/3 Acer Iconia A1-810 Motherboard Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Motherboard Replacement: 8 단계, 이미지 1/3 Acer Iconia A1-810 Motherboard Replacement: 8 단계, 이미지 2/3 Acer Iconia A1-810 Motherboard Replacement: 8 단계, 이미지 3/3
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Motherboard Replacement: 9 단계, 이미지 1/1
    • Gently lift motherboard out.
    • The edges may be sharp.
결론
다른 7명이 해당 안내서를 완성하였습니다.
John
회원 가입일: 01/29/15
635 평판
안내서 3개 작성하였습니다
UWT Liner: Group 3 UWT Liner: Group 3 회원
Community
5 회원들
안내서 3개 작성하였습니다
댓글 8개
I need main ic part num A1-810 iconia I need main ic
mehwish - 답글
It was damage because high voltage
mehwish - 답글
I need main ic
mehwish - 답글
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
theblackfox2 - 답글
Hi there i need acer lconia A3 main bord how much it will cost me ?
Muhammad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 25
전체 시간: 5,413
