소개
Replace the motherboard in a Acer Iconia A1-810.
필요한 것
Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
댓글 8개
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
