주요 콘텐츠로 건너뛰기
Acer Iconia A1-810 Screen Replacement
필요한 것
  1. Acer Iconia A1-810 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
  2. Acer Iconia A1-810 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Screen Replacement: 3 단계, 이미지 1/1
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
  4. Acer Iconia A1-810 Screen Replacement: 4 단계, 이미지 1/2 Acer Iconia A1-810 Screen Replacement: 4 단계, 이미지 2/2
    • Remove battery from adhesive.
  5. Acer Iconia A1-810 Screen Replacement, Motherboard: 5 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
  6. Acer Iconia A1-810 Screen Replacement: 6 단계, 이미지 1/2 Acer Iconia A1-810 Screen Replacement: 6 단계, 이미지 2/2
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
  7. Acer Iconia A1-810 Screen Replacement: 7 단계, 이미지 1/3 Acer Iconia A1-810 Screen Replacement: 7 단계, 이미지 2/3 Acer Iconia A1-810 Screen Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Screen Replacement: 8 단계, 이미지 1/3 Acer Iconia A1-810 Screen Replacement: 8 단계, 이미지 2/3 Acer Iconia A1-810 Screen Replacement: 8 단계, 이미지 3/3
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Screen Replacement: 9 단계, 이미지 1/1
    • Gently lift motherboard out.
    • The edges may be sharp.
  10. Acer Iconia A1-810 Screen Replacement, Screen: 10 단계, 이미지 1/3 Acer Iconia A1-810 Screen Replacement, Screen: 10 단계, 이미지 2/3 Acer Iconia A1-810 Screen Replacement, Screen: 10 단계, 이미지 3/3
    • Lift the three copper foils from the plate.
  11. Acer Iconia A1-810 Screen Replacement: 11 단계, 이미지 1/1
    • Add strips of tape to the sides of the device.
  12. Acer Iconia A1-810 Screen Replacement: 12 단계, 이미지 1/2 Acer Iconia A1-810 Screen Replacement: 12 단계, 이미지 2/2
    • Wedge the Jimmy between the screen and body of the device and ease around the whole edge of the device.
    • A reasonable amount of force is necessary to wedge deep into the screen.
    • The screen will possibly crack more and the debris will be scattered.
  13. Acer Iconia A1-810 Screen Replacement: 13 단계, 이미지 1/3 Acer Iconia A1-810 Screen Replacement: 13 단계, 이미지 2/3 Acer Iconia A1-810 Screen Replacement: 13 단계, 이미지 3/3
    • While holding the side of the screen, press the metal plates behind the device to pop the screen out.
결론
다른 15명이 해당 안내서를 완성하였습니다.
John
회원 가입일: 01/29/15
635 평판
안내서 3개 작성하였습니다
UWT Liner: Group 3 UWT Liner: Group 3 회원
Community
5 회원들
안내서 3개 작성하였습니다
댓글 한 개
Before starting to remove the screen, remove the strip of black tape stuck over the screen ribbon cable (right hand end in the last picture) carefully lift the connector lock on the old screen connector and remove the ribbon cable completely.
Fit this ribbon cable to the new display before fitting the screen and the feed it through the slot provided as you install.
Michael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 10,248
