주요 콘텐츠로 건너뛰기
Acer Iconia A1-830 Battery Replacement
필요한 것
  1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: 1 단계, 이미지 1/2 Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: 1 단계, 이미지 2/2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Battery Replacement: 2 단계, 이미지 1/2 Acer Iconia A1-830 Battery Replacement: 2 단계, 이미지 2/2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Battery Replacement, Battery: 3 단계, 이미지 1/2 Acer Iconia A1-830 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Battery Replacement: 5 단계, 이미지 1/2 Acer Iconia A1-830 Battery Replacement: 5 단계, 이미지 2/2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Matt Champagne
회원 가입일: 10/20/15
458 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G6
3 회원들
안내서 5개 작성하였습니다
댓글 2개
Is it okay if the battery bends a slight bit when prying it off?
Doof - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 9,076
