주요 콘텐츠로 건너뛰기
Acer Iconia A1-830 Speaker Assembly Replacement
필요한 것
  1. Acer Iconia A1-830 Speaker Assembly Replacement, Disassembling Acer Iconia A1-830 Back Panel: 1 단계, 이미지 1/2 Acer Iconia A1-830 Speaker Assembly Replacement, Disassembling Acer Iconia A1-830 Back Panel: 1 단계, 이미지 2/2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Speaker Assembly Replacement: 2 단계, 이미지 1/2 Acer Iconia A1-830 Speaker Assembly Replacement: 2 단계, 이미지 2/2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Speaker Assembly Replacement, Battery: 3 단계, 이미지 1/2 Acer Iconia A1-830 Speaker Assembly Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Speaker Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Speaker Assembly Replacement: 5 단계, 이미지 1/2 Acer Iconia A1-830 Speaker Assembly Replacement: 5 단계, 이미지 2/2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Speaker Assembly Replacement, Speaker Assembly: 6 단계, 이미지 1/3 Acer Iconia A1-830 Speaker Assembly Replacement, Speaker Assembly: 6 단계, 이미지 2/3 Acer Iconia A1-830 Speaker Assembly Replacement, Speaker Assembly: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the small clear plastic cover from the speaker connector with the metal tweezers.
    • Lift out the speaker connector using the metal tweezers.
  7. Acer Iconia A1-830 Speaker Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the two 2.8 mm Philips #00 screws using the #000 sized Philips screwdriver.
    • Remove the 3.7 mm Philips #000 screw using the #000 size Philips screwdriver.
  8. Acer Iconia A1-830 Speaker Assembly Replacement: 8 단계, 이미지 1/1
    • Lift out the speaker assembly form the plastic frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brendan Coveney
회원 가입일: 10/18/15
593 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 638
