주요 콘텐츠로 건너뛰기
Acer Iconia A100 3G Antenna Replacement
필요한 것
  1. Acer Iconia A100 3G Antenna Replacement, Battery: 1 단계, 이미지 1/1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 3G Antenna Replacement: 2 단계, 이미지 1/1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 3G Antenna Replacement: 3 단계, 이미지 1/1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 3G Antenna Replacement: 4 단계, 이미지 1/1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 3G Antenna Replacement: 5 단계, 이미지 1/2 Acer Iconia A100 3G Antenna Replacement: 5 단계, 이미지 2/2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 3G Antenna Replacement, I/O Board: 6 단계, 이미지 1/1
    • Gently peel off any tape securing the FPC to the main plate.
  7. Acer Iconia A100 3G Antenna Replacement: 7 단계, 이미지 1/3 Acer Iconia A100 3G Antenna Replacement: 7 단계, 이미지 2/3 Acer Iconia A100 3G Antenna Replacement: 7 단계, 이미지 3/3
    • Locate the two connectors at each end of the FPC.
    • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
    • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
    • You should now see the yellow-colored strip on the metal base marking the location of the FPC
  8. Acer Iconia A100 3G Antenna Replacement: 8 단계, 이미지 1/1
    • Locate the L-shaped I/O Board.
    • Locate the gray 3G Antenna wire.
    • If the gray 3G Antenna wire is connected to your I/O Board, disconnect it. If for some reason the 3G Antenna wire is already disconnected from the I/O Board (as it was in this device) simply lift it out of the way.
  9. Acer Iconia A100 3G Antenna Replacement: 9 단계, 이미지 1/2 Acer Iconia A100 3G Antenna Replacement: 9 단계, 이미지 2/2
    • Locate the microphone cable.
    • You should be able to gently pull it out of its socket using only your fingers.
    • The spudger is used in the photo merely to hold up / identify the disconnected mic cable head.
  10. Acer Iconia A100 3G Antenna Replacement: 10 단계, 이미지 1/3 Acer Iconia A100 3G Antenna Replacement: 10 단계, 이미지 2/3 Acer Iconia A100 3G Antenna Replacement: 10 단계, 이미지 3/3
    • Locate the light sensor connector.
    • Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
    • This is a ZIF (zero insertion force) connector, which requires no force to remove / plug in the connector.
    • Please make sure you lift up on the small retaining flap on the connector, not the connector itself!
    • Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
  11. Acer Iconia A100 3G Antenna Replacement: 11 단계, 이미지 1/2 Acer Iconia A100 3G Antenna Replacement: 11 단계, 이미지 2/2
    • Carefully lift the I/O Board off the device.
  12. Acer Iconia A100 3G Antenna Replacement, 3G Antenna: 12 단계, 이미지 1/3 Acer Iconia A100 3G Antenna Replacement, 3G Antenna: 12 단계, 이미지 2/3 Acer Iconia A100 3G Antenna Replacement, 3G Antenna: 12 단계, 이미지 3/3
    • Use the flat end of a spudger to pry the gold connector of the antenna cable straight up from the unit.
    • While a metal spudger tool is shown here, it is best to use a plastic spudger/opening tool when possible, and only use a metal spudger as a last resort!
    • With the 3G Antenna cable disconnected from the device, lift the 3G Antenna module out and remove it from the device.
결론
Nacarri Murphy
회원 가입일: 03/01/17
106 평판
안내서 1개 작성함
IUPUI, Team S1-G4, Harley Spring 2017 IUPUI, Team S1-G4, Harley Spring 2017 회원
IUPUI-HARLEY-S17S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 229
