주요 콘텐츠로 건너뛰기
Acer Iconia A100 Battery Replacement
필요한 것
  1. Acer Iconia A100 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Battery Replacement: 3 단계, 이미지 1/1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Battery Replacement: 4 단계, 이미지 1/1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Battery Replacement: 5 단계, 이미지 1/2 Acer Iconia A100 Battery Replacement: 5 단계, 이미지 2/2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Omar Acosta
회원 가입일: 03/03/15
526 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 13-3, Blackburne Winter 2015 Sam Houston State, Team 13-3, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G3
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,863
