주요 콘텐츠로 건너뛰기
Acer Iconia A100 Speakers Replacement
필요한 것
  1. Acer Iconia A100 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Speakers Replacement: 2 단계, 이미지 1/1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Speakers Replacement: 3 단계, 이미지 1/1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Speakers Replacement: 4 단계, 이미지 1/1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Speakers Replacement: 5 단계, 이미지 1/2 Acer Iconia A100 Speakers Replacement: 5 단계, 이미지 2/2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 Speakers Replacement, Speakers: 6 단계, 이미지 1/3 Acer Iconia A100 Speakers Replacement, Speakers: 6 단계, 이미지 2/3 Acer Iconia A100 Speakers Replacement, Speakers: 6 단계, 이미지 3/3
    • Locate the speakers module, which consists of 2 square black speakers connected by wires.
    • Locate the white and blue Home Key FFC ribbon cable between the speakers.
    • Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
    • While a metal spudger tool is shown here and may be used, it is best to use a plastic spudger or opening tool when possible. It is easier to damage cables when using metal tools, so be extra cautious when using a metal spudger like the one shown here!
  7. Acer Iconia A100 Speakers Replacement: 7 단계, 이미지 1/2 Acer Iconia A100 Speakers Replacement: 7 단계, 이미지 2/2
    • Locate the speaker cable. Use your fingers to pinch each side of the black head of the speaker cable, and gently pull it out of its socket.
    • The metal spudger shown in the photo is used only to identify the speaker cable, not remove it.
    • If you're unable to get a good grip on the black connector head itself, gently pull from the wires near the connector head's base.
    • Be sure to pull on the wires near the base and evenly on the full width of the wires so no individual wire is over-strained, which may cause damage!
  8. Acer Iconia A100 Speakers Replacement: 8 단계, 이미지 1/2 Acer Iconia A100 Speakers Replacement: 8 단계, 이미지 2/2
    • Unscrew the 4mm Phillips screws securing the speakers module to the device using a Phillips #00 screwdriver.
    • There are two 4mm screws in total (one screw securing each speaker).
  9. Acer Iconia A100 Speakers Replacement: 9 단계, 이미지 1/2 Acer Iconia A100 Speakers Replacement: 9 단계, 이미지 2/2
    • Now both speakers should be free. Use the edge of a spudger tool to lift each speaker off the device, or use your hands to simultaneously lift each square black speaker off of the device.
    • If intact, the two speakers should be connected by wires, forming a one-piece speakers module.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Omar Acosta
회원 가입일: 03/03/15
526 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 13-3, Blackburne Winter 2015 Sam Houston State, Team 13-3, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G3
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 329
