소개
The removal of the Motherboard is one of the initial steps in completely taking apart this tablet and is a moderately difficult process.
필요한 것
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
Two 2.0 mm screws (with the bigger head)
Four 2.5 mm screws (with the smaller head)
다른 한 분이 해당 안내서를 완성하였습니다.
