주요 콘텐츠로 건너뛰기
Acer Iconia B1-710 Screen Replacement
필요한 것
  1. Acer Iconia B1-710 Screen Replacement, Battery: 1 단계, 이미지 1/3 Acer Iconia B1-710 Screen Replacement, Battery: 1 단계, 이미지 2/3 Acer Iconia B1-710 Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Screen Replacement: 2 단계, 이미지 1/3 Acer Iconia B1-710 Screen Replacement: 2 단계, 이미지 2/3 Acer Iconia B1-710 Screen Replacement: 2 단계, 이미지 3/3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Screen Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Screen Replacement, Screen: 4 단계, 이미지 1/2 Acer Iconia B1-710 Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Unscrew all five 3 mm #000 Phillips screws.
  5. Acer Iconia B1-710 Screen Replacement: 5 단계, 이미지 1/2 Acer Iconia B1-710 Screen Replacement: 5 단계, 이미지 2/2
    • Unplug the LCD ribbon.
  6. Acer Iconia B1-710 Screen Replacement: 6 단계, 이미지 1/2 Acer Iconia B1-710 Screen Replacement: 6 단계, 이미지 2/2
    • Unplug the orange ribbon.
  7. Acer Iconia B1-710 Screen Replacement: 7 단계, 이미지 1/3 Acer Iconia B1-710 Screen Replacement: 7 단계, 이미지 2/3 Acer Iconia B1-710 Screen Replacement: 7 단계, 이미지 3/3
    • Unplug the white wire from the motherboard.
    • Unplug the black wire from the motherboard.
  8. Acer Iconia B1-710 Screen Replacement: 8 단계, 이미지 1/1
    • Pull the motherboard off of the tablet.
  9. Acer Iconia B1-710 Screen Replacement: 9 단계, 이미지 1/1
    • Use a blow dryer to melt the glue holding the LCD display in place.
    • Patience is key. It will take a few minutes to melt the glue.
  10. Acer Iconia B1-710 Screen Replacement: 10 단계, 이미지 1/3 Acer Iconia B1-710 Screen Replacement: 10 단계, 이미지 2/3 Acer Iconia B1-710 Screen Replacement: 10 단계, 이미지 3/3
    • Peel the LCD display.
    • This piece is fragile and needs to be peeled with care.
    • Parts may be hot.
  11. Acer Iconia B1-710 Screen Replacement: 11 단계, 이미지 1/1
    • Use a blow dryer to melt the glue from the thin metal frame.
    • This piece is metal and will become hot during this process.
  12. Acer Iconia B1-710 Screen Replacement: 12 단계, 이미지 1/2 Acer Iconia B1-710 Screen Replacement: 12 단계, 이미지 2/2
    • Peel off the thin metal frame.
    • Be careful not to bend the frame as it is very thin.
  13. Acer Iconia B1-710 Screen Replacement: 13 단계, 이미지 1/1
    • Use a blow dryer to melt the glue between the metal frame and the screen.
    • The frame will get hot.
  14. Acer Iconia B1-710 Screen Replacement: 14 단계, 이미지 1/2 Acer Iconia B1-710 Screen Replacement: 14 단계, 이미지 2/2
    • Peel the frame from the screen.
    • Be careful when peeling the screen or it may sustain further damage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Weber
회원 가입일: 03/26/17
358 평판
안내서 3개 작성하였습니다
IUPUI, Team S3-G5, Baechle Spring 2017 IUPUI, Team S3-G5, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 924
