주요 콘텐츠로 건너뛰기
Acer Iconia B1-710 Tablet Camera Replacement
필요한 것
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: 1 단계, 이미지 1/3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: 1 단계, 이미지 2/3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: 2 단계, 이미지 1/3 Acer Iconia B1-710 Tablet Camera Replacement: 2 단계, 이미지 2/3 Acer Iconia B1-710 Tablet Camera Replacement: 2 단계, 이미지 3/3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: 4 단계, 이미지 1/2 Acer Iconia B1-710 Tablet Camera Replacement, Camera: 4 단계, 이미지 2/2
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: 5 단계, 이미지 1/2 Acer Iconia B1-710 Tablet Camera Replacement: 5 단계, 이미지 2/2
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: 6 단계, 이미지 1/2 Acer Iconia B1-710 Tablet Camera Replacement: 6 단계, 이미지 2/2
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: 7 단계, 이미지 1/3 Acer Iconia B1-710 Tablet Camera Replacement: 7 단계, 이미지 2/3 Acer Iconia B1-710 Tablet Camera Replacement: 7 단계, 이미지 3/3
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: 8 단계, 이미지 1/1
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: 9 단계, 이미지 1/3 Acer Iconia B1-710 Tablet Camera Replacement: 9 단계, 이미지 2/3 Acer Iconia B1-710 Tablet Camera Replacement: 9 단계, 이미지 3/3
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
결론
To reassemble your device, follow the above instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Weber
회원 가입일: 03/26/17
358 평판
안내서 3개 작성하였습니다
IUPUI, Team S3-G5, Baechle Spring 2017 IUPUI, Team S3-G5, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 352
