주요 콘텐츠로 건너뛰기
Acer Iconia B1-720 Front Facing Camera Replacement
필요한 것
  1. Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 2/3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 3/3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Front Facing Camera Replacement: 2 단계, 이미지 1/3 Acer Iconia B1-720 Front Facing Camera Replacement: 2 단계, 이미지 2/3 Acer Iconia B1-720 Front Facing Camera Replacement: 2 단계, 이미지 3/3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Front Facing Camera Replacement: 3 단계, 이미지 1/2 Acer Iconia B1-720 Front Facing Camera Replacement: 3 단계, 이미지 2/2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: 4 단계, 이미지 1/3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: 4 단계, 이미지 2/3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: 4 단계, 이미지 3/3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Front Facing Camera Replacement: 5 단계, 이미지 1/2 Acer Iconia B1-720 Front Facing Camera Replacement: 5 단계, 이미지 2/2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Front Facing Camera Replacement: 6 단계, 이미지 1/2 Acer Iconia B1-720 Front Facing Camera Replacement: 6 단계, 이미지 2/2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  7. Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: 7 단계, 이미지 1/3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: 7 단계, 이미지 2/3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: 7 단계, 이미지 3/3
    • Remove the yellow tape covering both ribbons in the two photos shown.
  8. Acer Iconia B1-720 Front Facing Camera Replacement: 8 단계, 이미지 1/2 Acer Iconia B1-720 Front Facing Camera Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  9. Acer Iconia B1-720 Front Facing Camera Replacement: 9 단계, 이미지 1/3 Acer Iconia B1-720 Front Facing Camera Replacement: 9 단계, 이미지 2/3 Acer Iconia B1-720 Front Facing Camera Replacement: 9 단계, 이미지 3/3
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  10. Acer Iconia B1-720 Front Facing Camera Replacement: 10 단계, 이미지 1/2 Acer Iconia B1-720 Front Facing Camera Replacement: 10 단계, 이미지 2/2
    • Use tweezers to gently remove black ribbon from locking mechanism.
  11. Acer Iconia B1-720 Front Facing Camera Replacement: 11 단계, 이미지 1/3 Acer Iconia B1-720 Front Facing Camera Replacement: 11 단계, 이미지 2/3 Acer Iconia B1-720 Front Facing Camera Replacement: 11 단계, 이미지 3/3
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
  12. Acer Iconia B1-720 Front Facing Camera Replacement, Front Facing Camera: 12 단계, 이미지 1/1
    • Flip the motherboard over so that you see the camera, micro usb port, and headphone jack.
    • The object marked in red is the camera.
  13. Acer Iconia B1-720 Front Facing Camera Replacement: 13 단계, 이미지 1/2 Acer Iconia B1-720 Front Facing Camera Replacement: 13 단계, 이미지 2/2
    • Grab and gently lift the camera up from the motherboard until it becomes disconnected.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kervis Boston
회원 가입일: 03/18/15
479 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 회원
MTU-LAUER-S15S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 399
