필요한 것
Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
Tug gently on microphone to remove from slot.
Flip the motherboard over so that you see the camera, micro usb port, and headphone jack.
다른 한 분이 해당 안내서를 완성하였습니다.
