소개
By using this guide, you will be able to replace the speaker or microphone from your tablet.
필요한 것
Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
Tug gently on microphone to remove from slot.
거의 끝나갑니다!
결론
