주요 콘텐츠로 건너뛰기
Acer Iconia B1-720 Rear Case Replacement
필요한 것
  1. Acer Iconia B1-720 Rear Case Replacement, Rear Case: 1 단계, 이미지 1/3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: 1 단계, 이미지 2/3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: 1 단계, 이미지 3/3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Rear Case Replacement: 2 단계, 이미지 1/3 Acer Iconia B1-720 Rear Case Replacement: 2 단계, 이미지 2/3 Acer Iconia B1-720 Rear Case Replacement: 2 단계, 이미지 3/3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Rear Case Replacement: 3 단계, 이미지 1/2 Acer Iconia B1-720 Rear Case Replacement: 3 단계, 이미지 2/2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Phillip Keavey
회원 가입일: 03/17/15
319 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 회원
MTU-LAUER-S15S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 839
