주요 콘텐츠로 건너뛰기
Acer Iconia B1-A71 LCD Display Replacement
필요한 것
동영상 개요
  1. Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: 1 단계, 이미지 1/3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: 1 단계, 이미지 2/3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: 1 단계, 이미지 3/3
    • Switch-off the tablet.
    • If you can't switch it off, use the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 LCD Display Replacement: 2 단계, 이미지 1/2 Acer Iconia B1-A71 LCD Display Replacement: 2 단계, 이미지 2/2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 LCD Display Replacement: 3 단계, 이미지 1/3 Acer Iconia B1-A71 LCD Display Replacement: 3 단계, 이미지 2/3 Acer Iconia B1-A71 LCD Display Replacement: 3 단계, 이미지 3/3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 LCD Display Replacement: 4 단계, 이미지 1/3 Acer Iconia B1-A71 LCD Display Replacement: 4 단계, 이미지 2/3 Acer Iconia B1-A71 LCD Display Replacement: 4 단계, 이미지 3/3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 LCD Display Replacement: 5 단계, 이미지 1/3 Acer Iconia B1-A71 LCD Display Replacement: 5 단계, 이미지 2/3 Acer Iconia B1-A71 LCD Display Replacement: 5 단계, 이미지 3/3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
결론
다른 6명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,536개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 11,028
