주요 콘텐츠로 건너뛰기
Acer Iconia B1-A71 Touch Screen Glass Replacement
필요한 것
동영상 개요
  1. Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: 1 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: 1 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: 1 단계, 이미지 3/3
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 Touch Screen Glass Replacement: 2 단계, 이미지 1/2 Acer Iconia B1-A71 Touch Screen Glass Replacement: 2 단계, 이미지 2/2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 Touch Screen Glass Replacement: 3 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 3 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 3 단계, 이미지 3/3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 Touch Screen Glass Replacement: 4 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 4 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 4 단계, 이미지 3/3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 Touch Screen Glass Replacement: 5 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 5 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 5 단계, 이미지 3/3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
  6. Acer Iconia B1-A71 Touch Screen Glass Replacement: 6 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 6 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 6 단계, 이미지 3/3
    • Warm up the touch screen.
    • Start separating from one of the corners. With a cutter, make place for a plastic tool.
    • Keep warm the touchscreen to separate it easily.
    • For us is important to keep only the frame.
  7. Acer Iconia B1-A71 Touch Screen Glass Replacement: 7 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 7 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 7 단계, 이미지 3/3
    • Use again hot air and a plastic tools to separate the metal screen frame / holder.
  8. Acer Iconia B1-A71 Touch Screen Glass Replacement: 8 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 8 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 8 단계, 이미지 3/3
    • Before installing the new touch screen, clean the frame and put double side adhesive tape.
    • For the cleaning you can use an alcohol.
  9. Acer Iconia B1-A71 Touch Screen Glass Replacement: 9 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 9 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 9 단계, 이미지 3/3
    • Again use a double side adhesive tape to install the the metal LCD frame.
  10. Acer Iconia B1-A71 Touch Screen Glass Replacement: 10 단계, 이미지 1/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 10 단계, 이미지 2/3 Acer Iconia B1-A71 Touch Screen Glass Replacement: 10 단계, 이미지 3/3
결론
다른 6명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,527개 작성하였습니다
댓글 한 개
Hello, i have followed all these instructions but the touch screen desn't work in spite of a reset by the little button and a wipe.
Please, how can i resolve this problem?
houssnijanah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 25,098
