주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If one or both of your cameras are faulty, they can be removed through the use of a plastic opening tool and a Phillips #00 screwdriver.
  1. Make sure the device is powered off. Pry open media port cover at the top of the tablet.
    • Make sure the device is powered off.
    • Pry open media port cover at the top of the tablet.
    • Use the Phillips 00 screwdriver to remove the 1 mm screw.
  2. Using the metal spudger, carefully pry open the back cover. Using the metal spudger, carefully pry open the back cover. Using the metal spudger, carefully pry open the back cover.
    • Using the metal spudger, carefully pry open the back cover.
  3. Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out. Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out. Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out.
    • Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out.
  4. Use the plastic opening tool to pry up the rear facing camera. Once removed the front facing camera will come out as well. Use the plastic opening tool to pry up the rear facing camera. Once removed the front facing camera will come out as well.
    • Use the plastic opening tool to pry up the rear facing camera. Once removed the front facing camera will come out as well.
결론
Austin Pickart
회원 가입일: 2017년 09월 28일
619 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 회원
USFT-NANCE-F17S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 452
