소개
In order to remove the motherboard, you will need both a plastic opening tool and a Phillips #00 screwdriver. In addition to that, all the tape surrounding the motherboard will need to be removed.
필요한 것
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
The button flex cable retaining clip is broken, do you have this available?
