주요 콘텐츠로 건너뛰기
Acer Iconia One 10 B3-A30 Repair Motherboard Replacement
필요한 것
  1. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 2 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 2 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 2 단계, 이미지 3/3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 4 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 4 단계, 이미지 2/2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 5 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 5 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 5 단계, 이미지 3/3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 7 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 7 단계, 이미지 2/2
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 8 단계, 이미지 1/1
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 9 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 9 단계, 이미지 2/2
    • Using the small plastic tool, carefully pry the motherboard out of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Austin Pickart
회원 가입일: 09/28/17
688 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 회원
USFT-NANCE-F17S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
The button flex cable retaining clip is broken, do you have this available?
Craig Olmscheid - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 3,786
