주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In order to remove the motherboard, you will need both a plastic opening tool and a Phillips #00 screwdriver. In addition to that, all the tape surrounding the motherboard will need to be removed.
  1. Make sure the device is powered off. Open media port cover at the top of the tablet.
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Using the metal spudger, carefully pry open the back cover. Using the metal spudger, carefully pry open the back cover. Using the metal spudger, carefully pry open the back cover.
    • Using the metal spudger, carefully pry open the back cover.
  3. Remove small section of grey tape.
    • Remove small section of grey tape.
  4. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  5. Unplug the connection cord from the motherboard. Unplug the connection cord from the motherboard.
    • Unplug the connection cord from the motherboard.
  6. Try to remove the battery by pulling on the blue tabs. If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery. Be very cautious not to puncture or bend the battery.
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  7. Remove all of the tape surrounding the motherboard. Remove all of the tape surrounding the motherboard. Remove all of the tape surrounding the motherboard.
    • Remove all of the tape surrounding the motherboard.
  8. Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out. Now, disconnect the two smaller black and red cords from the motherboard.
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  9. Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  10. Using the small plastic tool, carefully pry the motherboard out of the device. Using the small plastic tool, carefully pry the motherboard out of the device.
    • Using the small plastic tool, carefully pry the motherboard out of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Austin Pickart
회원 가입일: 2017년 09월 28일
628 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 회원
USFT-NANCE-F17S1G5
4 회원들
안내서 5개 작성하였습니다
The button flex cable retaining clip is broken, do you have this available?
Craig Olmscheid - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 42
전체 시간: 2,899
