소개
In order to remove the motherboard, you will need both a plastic opening tool and a Phillips #00 screwdriver. In addition to that, all the tape surrounding the motherboard will need to be removed.
부품
지정된 부품이 없습니다.
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
The button flex cable retaining clip is broken, do you have this available?
