소개
After the motherboard has been removed, you now have access to the power switch. You will need to use a plastic opening tool to pop the switch out.
필요한 것
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
Depress power switch using finger, and simultaneously pry in same direction with a plastic opening tool.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
