소개
After removing the battery, motherboard, and speakers, you can access the screen. Through the use of a Phillips #00 bit and a black plastic spudger, we will show you how to remove the screen.
필요한 것
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 11개
nice job people!
It worked! I’m very happy
marmaesker - 답글
Fantastic set of instructions. Very much appreciated. Cheers very much!!
To replace just the digitiser glass, could I just disconnect the black digitiser ribbon shown in step 7 and then use a heat gun on the front and remove the glass that way? Then I would just need to slide the new ribbon cable through and seal, with no need to remove the motherboard, battery etc.
In theory i’m sure this would work, I might try it and give an update in a week or so once my part arrives.
So for glass only does the battery and motherboard need to come out?
thanks so much im soglad I don't have to use a mouse to type on my tablet anymore!!! what is thebest way to glue the battery though?
tout s’est bien passé remplacement effectué, mais il n’est absolument pas nécessaire de retirer la batterie, en fait en déconnectant la tresse façade et en enlevant toutes les vis, on peut tout sortir d’un coup, rien d’autre à débrancher.
La seule vis à ne pas oublier d’enlever c’est celle qui est sous le petit carré de papier collant à proximité de la prise USB
Si non beau travail mais à simplifier
