주요 콘텐츠로 건너뛰기
Acer Iconia One 10 B3-A30 Repair Screen Replacement
필요한 것
  1. Acer Iconia One 10 B3-A30 Repair Screen Replacement, Battery: 1 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 2 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 2 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 2 단계, 이미지 3/3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 3 단계, 이미지 1/1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 4 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 4 단계, 이미지 2/2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 5 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 5 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 5 단계, 이미지 3/3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Screen Replacement, Motherboard: 6 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Motherboard: 6 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 7 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 7 단계, 이미지 2/2
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 8 단계, 이미지 1/1
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 9 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 9 단계, 이미지 2/2
    • Using the small plastic tool, carefully pry the motherboard out of the device.
  10. Acer Iconia One 10 B3-A30 Repair Screen Replacement, Screen: 10 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Screen: 10 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Screen: 10 단계, 이미지 3/3
    • Using a plastic spudger pry the square connection away from the screen.
  11. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 11 단계, 이미지 1/1
    • Using the Philips #00 head unscrew the screw holding in the small plate.
  12. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 12 단계, 이미지 1/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 12 단계, 이미지 2/3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 12 단계, 이미지 3/3
    • Using the Philips #00 unscrew the remaining 4 screws along the two speakers.
  13. Acer Iconia One 10 B3-A30 Repair Screen Replacement: 13 단계, 이미지 1/2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: 13 단계, 이미지 2/2
    • Using the plastic spudger gently pry the screen along the plastic clips.
    • Once at least 1/2 of the screen is unclipped slide it out of the frame using hands.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Austin Pickart
회원 가입일: 09/28/17
688 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 회원
USFT-NANCE-F17S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 11개
It worked! I’m very happy
marmaesker - 답글
nice job
Linh Pham
Linh Pham - 답글
This helped out a lot, thanks
feje75 - 답글
Fantastic set of instructions. Very much appreciated. Cheers very much!!
Chris Wilson - 답글
To replace just the digitiser glass, could I just disconnect the black digitiser ribbon shown in step 7 and then use a heat gun on the front and remove the glass that way? Then I would just need to slide the new ribbon cable through and seal, with no need to remove the motherboard, battery etc.
In theory i’m sure this would work, I might try it and give an update in a week or so once my part arrives.
Liam Flatley - 답글
So for glass only does the battery and motherboard need to come out?
northstar -
thanks so much im soglad I don't have to use a mouse to type on my tablet anymore!!! what is thebest way to glue the battery though?
CozmicPlayz Minecraft - 답글
Is the LCD fused to the touch digitizer here? Wondering if I can just get the LCD, or need the complete assembly, because my touch layer still works, just the LCD is cracked
tipoo - 답글
tout s’est bien passé remplacement effectué, mais il n’est absolument pas nécessaire de retirer la batterie, en fait en déconnectant la tresse façade et en enlevant toutes les vis, on peut tout sortir d’un coup, rien d’autre à débrancher.
La seule vis à ne pas oublier d’enlever c’est celle qui est sous le petit carré de papier collant à proximité de la prise USB
Si non beau travail mais à simplifier
Daniel Popy - 답글
That wasn’t too bad, all fixed!
Just try to get the pull tabs out straight and clean, otherwise having to manipulate the battery (which seems to bend easy!) can be worrying.
tipoo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 19
전체 시간: 12,798
