이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
Try to remove the battery by pulling on the blue tabs.
If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
Now, disconnect the two smaller black and red cords from the motherboard.
Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
Using the same screwdriver remove the other three screws on the motherboard.
Using the small plastic tool, carefully pry the motherboard out of the device.
Using a plastic spudger pry the square connection away from the screen.
Using the Philips #00 head unscrew the screw holding in the small plate.
Using the Philips #00 unscrew the remaining 4 screws along the two speakers.
Using the plastic spudger gently pry the screen along the plastic clips.
Once at least 1/2 of the screen is unclipped slide it out of the frame using hands.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 11개
nice job people!
It worked! I’m very happy
marmaesker - 답글
Fantastic set of instructions. Very much appreciated. Cheers very much!!
