주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The battery is essential to the Acer Iconia One 7 as it powers the entire device. One should be careful when replacing a battery because it may be dangerous if the battery is punctured. Taking apart the battery itself without proper safety precautions could prove to be hazardous to one’s health. Power down the device before beginning this repair.
  1. Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Using a plastic opening tool, separate the back cover from the main device.
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Turn the tablet over so the battery is facing up.
    • Turn the tablet over so the battery is facing up.
  4. Carefully pull back the black tape covering the battery lead connector. Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Using a plastic card or opening pick,  separate the battery from the rest of the device. Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery. Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ahmad Kayali
회원 가입일: 2015년 09월 01일
407 평판
안내서 1개 작성함
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G5
3 회원들
안내서 5개 작성하였습니다
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - 답글
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - 답글
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 35
30일 전: 130
전체 시간: 15,936
