이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
Using a plastic opening tool, separate the back cover from the main device.
Open each side continuously to ensure all sides have been separated.
Carefully pull back the black tape covering the battery lead connector.
Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
이 단계에 사용된 도구:Plastic Cards$2.99-
Using a plastic card or opening pick, separate the battery from the rest of the device.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 4개
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - 답글
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
Where I can order the new battery part?
