주요 콘텐츠로 건너뛰기
Acer Iconia One 7 Front Facing Camera Replacement
필요한 것
  1. Acer Iconia One 7 Front Facing Camera Replacement, Front-Facing Camera: 1 단계, 이미지 1/1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Front Facing Camera Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Front Facing Camera Replacement: 3 단계, 이미지 1/1
    • Turn tablet over.
    • Locate front-facing camera.
  4. Acer Iconia One 7 Front Facing Camera Replacement: 4 단계, 이미지 1/1
    • Pull black tape with front-facing camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael
회원 가입일: 09/03/15
519 평판
안내서 4개 작성하였습니다
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G5
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Be carefful when pulling the stick tape. It is very strong and can break the flex cable of the camera and other flex cables...
Egas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 12
전체 시간: 1,159
