이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin at any side of the tablet.
With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
Using a plastic opening tool, separate the back cover from the main device
Open each side continuously to ensure all sides have been separated,
Turn tablet over.
Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
다른 4명이 해당 안내서를 완성하였습니다.
