주요 콘텐츠로 건너뛰기
Acer Iconia One 7 Rear-Facing Camera Replacement
필요한 것
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: 1 단계, 이미지 1/1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: 3 단계, 이미지 1/1
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: 4 단계, 이미지 1/2 Acer Iconia One 7 Rear-Facing Camera Replacement: 4 단계, 이미지 2/2
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: 5 단계, 이미지 1/2 Acer Iconia One 7 Rear-Facing Camera Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Take out film object using tweezers.
    • Using tweezers take out camera.
결론
Michael
회원 가입일: 09/03/15
519 평판
안내서 4개 작성하였습니다
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G5
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
How to get new camera if the original camera is damaged
Prakash Hasabnis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 15
전체 시간: 443
